maxflutehd
Hi!
So I'm pretty new to the analog audio community and this is kind of my first project.
The Story:
My dad gifted me a broken A760II.
It had some shorted output transistors, which took the drivers and pre-drivers with them. After fiixing up the PSU replacing burnt resistors, some dried up caps (surprised that most were still good ESR) and substituting the shorted transistors it started working again.
It sounds really good!
The Problem(s):
- When I try to adjust the photocurrent check voltage of the PSU, the maxium (the variable resistor maxed out) I can get is 1,05V, the manual specifies 1.2V though. Whats up with that??
- After using it for a while I noticed that the listening level monitor stopped working.
What I already analysed:
- I don't really understand the schematics, yet, and I don't really know how things play together- sadly.
- So, for the photocurrent, I couldn't analyse much.
- For the listening level monitor, I checked the led and the sliding potentiometer.
I also checked the IC302 Op-Amp's inputs. The non-inverting input (Pin5) fluctuates down with the music and volume at 0,010-0,200V with the slider all the way right.
The inverting input (Pin6) stays at 1,45V all the time. That gives an output (Pin7) of -16.2V, so the diode blocks the voltage to the LED.
I would appreciate any help and explanation of how the circuit works!!
Thank you so much!
The Story:
The Problem(s):
Thank you so much!
