Floorstanding Speaker Recomendations
Chris_M
Looking for a pair of floorstanding speakers to replace my Mission 751 bookshelf speakers and PSB sub. My budget is $1000 CAD (~$800 USD :( ). Would prefer to buy used as my money would go further and then I don't need to break in the speakers.
I use a little 5W Miniwatt tube amp (EL84 single ended). Listen to rock, blues, folk, indie, punk, alt-country and so on mainly on vinyl but sometimes I stream some crappy MP3s. Medium sized room.
What would you recommend for me?
Nice but only 89dB sensitivity.
philridebike said:
Something around 95-98db sensitive if you can find it, that's for sure.
Yeah forgot to mention I need something with a higher sensitivity rating. My Mission 751 are 89dB now. Eventually I am going to go to a tube preamp/SS power amp but I still want some efficient speakers.
I notice Klipsch makes some efficient floorstanding speakers. They look pretty nice. How are they?
I've been recommended Axion speakers from tube guys at the Dynaco Audio Forum.
Those look nice. I would be looking at the M60. A little pricey but I could probably find them used in my budget. I notice again they have a sensitivity of 91dB and want to be driven by a 10W amp at the min. The woofer is only 6.5”....hmm
Question:
Though I have a little low powered single ended tube amp now I will eventually be upgrading to a tube preamp and solid state power amp. Should I be limiting my floorstanding speaker search to units with high efficiency speakers? Basically what I am asking is will high efficiency speakers still be a “good idea” when I do upgrade my amp?
What you listen to also matters when upgrading on a budget and why get speakers to match current gear when your upgrading? I have found my 93.5 db speakers quite difficult to match with "affordable electronics".
Excuse me and my crappy equipment. I am just getting into this hobby, don't have massive amounts of money to throw around on all aspects on my setup now. Just looking for some information here.
For the long term, once you get the SS amp, I would recommend Infinity RS-IIIa/b's (or any of the Infinities in the RS series down to RS 6), great rock and roll speakers, but not very efficient though (5b's have 88 db sensitivity). You need some power to drive them, I got great results using Onkyo 9070 integrated (140 wpc at 4 Ohm) to drive RS-IIIa's.
Not everyone's cup of tea, but I'm happy with mine. Heritage series are very efficient - you can probably find Chorus or maybe Cornwalls within your budget, if you have room for them. Not sure of the efficiency, but KLF 20 & 30 and the CF3 or 4 also have good reputations.
Chris, where are you located? With a lower power, a horn loaded or a number of vintage speakers might be the answer.
Wharfedale W series will work. They can be had for well below your budget and while they will likely need caps even refurbished they will leave you a lot of excess cash.
Klipsch Heresys and Cornwalls also will work but, the Forte and Forte II may be more to your liking. Add Bob Crites magic and they are hard to beat. If lucky, you might even be able to locate a beatup set of LaScalas. Physical condition of these is not a big deal as most are unfinished. Again, Crites is your flight to person. There are other companies using horns you should also consider but, Klipsch is the most mainstream.
You also can go a might esoteric and find set of single drive full range systems such as the Lowther. These operate on flea power and provided you have an open mind, are really an amazing experience in the audio range you can hear. There is a whole world out there about these types of speakers and it should not be ignored. One of the best speakers I ever heard with female vocals was a Lowther. I would own the set today if I already was not so deeply vested with high powered amps.
Many vintage speakers from the tube period will easily meet your needs as back then 5 watt amps were very common. There is no need to apologize for what you have. There are a lot of us using console tube amps revamped as a power amp and they look and sound excellent. You may want to do a search on Magnavox tube amps as there are some threads about them.
It is easy to dump huge sums and buy big components to buy into a good system but, it can be far more satisfying to build a nice low cost, low powered system. I just downsized from a 100/chl system to a 20watt/chl system and love it as much and even better maybe.
