I have worked in my company's Instrument Services section as a repair tech for 20 years.
We do a lot of fluke meters,repairs and calibrations.My take on some fluke meters.
87---excellent,some problems with missing digits,fixed by cleaning lcd contact points.Calibration checks after 5 years dc always in spec.Ac has some dift temp and humidity affect it but in a shop should be ok.Uses 2 variable caps and one teflon variable,usually cal. is very close.Fluke 27,solid, only problem i see once in a blue moon is display locked up,again due to dirty lcd contacts.I checked a 15 year old unit and it was still in spec.This meter had been used outdoors etc.Fluke 8060A---pushbutton switches require cleaning occasionally.This is a dead accurate meter,great for high frequency work--only 2 amps max,only drawback.It would be my choice for lab type accuracy both dc and ac low and hf.Other flukes 73,77,179 etc. good for everyday use. 8050 another good meter kind of in the same vein as the 8060a,however I prefer the 8060A.This is my choice above all. Hope this helps.
