I haven't looked closely at the other stuff he has for sale but when he told you "Some of my amps don't have variable resistors to protect amps", he apparently meant that some of his designs use cathode bias, which is not adjustable. And the owners don't complain about the lack of adjustment.I genuinely want to help out small business and know he makes great gear just at this point pretty shitty customer service. . . .
And don't get me wrong I love it i just want to make sure I operate it in spec based on the circuit.
This was one of the email he sent me when I asked about manual and bias adjustment numbers
"""Yes you are right.
Bias voltage of 845 and 211 is different. The reason why I don't provide a manual for customers is to prevent "unexpected damage" by mis-adjustment. Some of my amps don't have variable resistors to protect amps. They don't complain about that. Works fine for years.
Please understand it.
Please don't adjust it, keep it in perfect condition. Let's talk later""""
And that was that
Thanks so much to all you guys for taking the time to answer and explain.All it explained to me is he’s willing to publish a (partial)schematic on a video, but won’t give one to you, a person who bought his product.
I agree and I obviously know more now so when I re read the email thats exactly what I thought. I am talking about this amp not your other builds.I haven't looked closely at the other stuff he has for sale but when he told you "Some of my amps don't have variable resistors to protect amps", he apparently meant that some of his designs use cathode bias, which is not adjustable. And the owners don't complain about the lack of adjustment.
That's fine, but if an amp can be adjusted owners need to know how.
If he's worried about damage from mis-adjustment he should realize that this is much more likely to happen if an owner decides to start adjusting things without any specific instructions.
It would be much less likely to happen if he provided written instructions with an explicit warning such as: When using 845s bias must be adjusted to xxV +/- xxV or damage may occur and warranty will be void. And same for the 211s.
If he's not willing to do that he should only sell amps that are cathode biased.
I don't understand why if something is so specific why not have a write up describing what you did and why you choose to go that route as to make your amp's different from others.The power supply schematic shows a negative bias supply (so not cathode bias), but the video describes different operating conditions for the two tubes. This likely means that the switch on the front to select each tube sets the correct bias voltage for that tube, not sure if it also alters the plate voltage as well. So it certainly would make sense that the way he shipped it is his ideal operating point for his circuit for each tube.
Safe to say I wouldn't buy something from someone that won't tell me the design bias conditions, but it seems that changing nothing is the best choice here.
You would not have to reverse engineer the whole amp. You could just open it up (and if you do please post lots of detailed pics) and measure the voltages on the pins with each type of output tube.I am tempted to send this off to a reputable builder and have him or her reverse engineer it and get me a proper spec and schematic to this power amplifier.
Since you would now know the plate voltages too, it will then be easy to calculate the plate dissipation which the designer considers to be the ideal for each tube type. Doing so would not be difficult.
It would also tell you exactly what changes are made when the amp is switched to use the different tubes. Does it only change the bias voltage or does it also change the plate voltage?
Take some good photos of the under side of the chassis... but be warned that there is probably about 1000V under there while it is working, and some of that will still be present after it is switched off unless he has bleeder resistors on the filter capacitors.
So be super extra careful. The 845 requires voltages which are much more dangerous than usual tube amps. I would let it sit unplugged for a day before opening it just to be sure.
any luck?Thanks so much to all you guys for taking the time to answer and explain.
yeah once I get some more time this up coming week I'll push again to try to get mr Young to provide me with at the vary least his bias points and safe operating parameters.
