Have no pic to show, but if you know the impedance of your FM antenna, it's fairly simple (to a semi tech<GG>)
You have 2 sets of 3 vertical screws.
For a 300 ohm twinlead antenna, the 3 screws above the switched max 50VA A/C outlet (right set of 3 vertical screws)
the antenna downlead should be attached to the top 2 screws. Rabbit ear antennas are 300 ohm (usually)
For a 75 ohm antenna, connect to the top 2 screws on the left set of 3 terminals (above the unswitched A/C outlet)
If you have a screw in coax at the end of the antenna, you can get a wire adapter, or get a 75 ohm to 300 ohm adapter
and connect to the 300 ohm pair of screws.
