receiver 75 ohm fm antenna connection
stu49
Hi,
Currently i am using an fm ribbon antenna on my ra 402 receiver. It has screw connections for 75 ohm coaxial antenna also.
How to i make an antenna to suit?
Cheers,
Stu
Basically one of the screws should be the ground connection and the other the signal carrier. The ground can sometimes be identified by a clamp attached to it. If there is a clamp, peel back the foil shield braid on the coax and use the clamp over the braid to hold the cable in place, the signal carrying wire attaching to the other screw. If there is no clamp, strip enough braid to be able to twist it so that the ground screw can grab it. I'm assuming you're planning on using an antenna that has a 75ohm feed cable.
It might be easier to just use a 75 ohm/300 ohm balun; connect your 75 ohm cable on one end, connect the 300 ohm balun leads to the 300 ohm terminals on your receiver.
If you go this route, you won't have to cut the fitting off the 75 ohm cable.
This is what I am hoping to replicate. It is about half a metre long. This one is from one of the other receivers.
cheers
Stu
Just go to your local thrift store and dig through the bins for a few minutes. You'll probably find one and be done with it!
So one of those antenna with the pal tv plug removed will work?
I've not seen coax cable that small readily available. Would a 75 ohm digital output lead for a cd player be ok with the plugs removed?
Now to source one of the pictured antennas.........
Yes, you could cut the plug off and just connect the two wires to the 300 ohm connectors on the receiver.
In the case of the picture that you posted earlier, it's not really coax going into the connector (if it's like the one I have); it's just two conductor wire. And -- I don't think they even bother with any kind of balun inside the connector, I think one wire is connected to the center pin and the other is connected to the shield/ground.
Probably not; you're better off working with twinlead or even just 2 conductor wire as in the "make one yourself" link I posted above.
4 foot piece of wire hooked to one of the 300ohm terminals. The chassis of the tuner is enough to serve as ground. Works for me.
Well the reception problem has been cured.
Whilst playing around with the ribbon antenna position i dropped it. It now hangs vertically and shazam! Perfect fm reception.
Case closed.
Thanks to those who endeavoured to assist.
Cheers,
Stu
Hi,
Cheers,
Stu
I notice you indicated screw connections (posts?) rather than coax connector for the 75ohm antenna (might be marked "unbalanced" as well)? They look like the 300ohm connectors if I'm reading you correctly.
I bought a Denon amp with this type of 75ohm connector rather than a coaxial. I was frustrated trying to find a 75ohm antenna without a coax connector. Of course, the proper 300-75ohm balun could have been used. I could also cut the connector off the 75ohm rabbit ears and connect the center and sheilding strands to the posts.
I ended up making a 75ohm dipole antenna out of spare 22guage speaker wire (no I don't use it on my high fi, picked up a spool somewhere) using these directions: http://www.ehow.com/how_5798387_make-reception-fm-radio-receiver.html. I tuned the length of the wire separation to several NPR stations around 90.5 on the fm dial using this calculator (http://www.radiobrandy.com/dipole1.html).
What you end up is a "T" antenna similar to the 300ohm folded dipole ones, but doesn't have the balancing wire connecting across the top of the T.
This made for the best reception out of all the things I tried. I was able to use a length of lamp cord that could get the antenna up through the wall and across the topside of a rafter beam in my living room. The extra altitude probably contributes the reception.
Yes, that's right. However they are not marked unbalanced.
I would have thought that the 300 ohm ribbon should have been set up in a T shape too. But not this one it seems. Hanging vertically seems to be the go.
Solved the reception problem and the tidiness problem in one fell swoop.
cheers
Stu
