... Using a fresh X-Acto knife, I split the aluminum cap across into four sections and then very carefully went in at an angle against the epoxy bead and slowly removed each quarter...
Once the first incision was made, there wasn't any looking back! I'm glad I did it though...they not only sound better, they look better! (It helps that I used to be a watchmaker.)Holy cow. You've got more guts than I do!
Anyone using the Madisound stands (or any stands)?
Also, is the quality of the plywood sufficient for a natural-type finish? I'm thinking about clear shellac (more of an amber color really).
Most don't listen to single-driver speakers for a real listening session, usually just background noise.
I'm using Lovan Jazz 6" stands which enable me to slightly angle them backwards so the drivers point towards my head from the listening spot. The finish on these was done by Celt and consists of two coats of Zar 'Natural Teak' (fogged), four coats of nitro-celluose lacquer (sprayed) and two applications of carnuba wax. They turned out very nice, IMO.
Go with the Madisound stands. You can finish them just like your speakers. It will look like part of the speaker.
Sand-fillable, right?
Can anyone tell me if there is damping material (and where / how much) in these cabinets before I buy these enclosures? (I like to know as it gives me a bit of an indication on what to expect during the build).
Many thanks in advance, AM.
IIRC the build instructions recommend 3 oz of Acousti-stuff in the upper chamber. I used this amount of plain-ol fiberfill.
Not called for in the instructions, but I also used fiberfill to stuff the interior voids in the cabinet. I didn't weigh it, just stuffed it in as tight as I could before final glue-up.
Many thanks for this information. Had read some suggestions about doing some damping in the upper chamber required but no details. Would hate to have these shipped out all the way to New Zealand (not cheap) and then discovering no details on damping and having to do lots of experimenting.
Regarding voids: one effective way is to use this expanding foam for filling cavities (designed for use around the home). Simplay ensure to have a hole in the wall in the right location and after completing insert the nozzle and let it doe its work. Then after it has hardened fill it up with a wooden plug. Unfortunately this is only going to work if you veneer it afterwards (or if you make special wooden plugs for "blind plugging" which have the grain in the same direction, often used in boat building but still visible).
