Found microscope. Work to check stylii?
Old Guy8
Cliff & Cleo
20160616_184950.jpg 20160616_184938.jpg Garage sale find, bought on wim to possibly inspect stylii for life. A couple threads have seem imply might be difficult to see wear and interpret.
Was told I have a college grade microscope. Eye pieces are 10x and 12x. Obvective lenses are 10x, 40x and 100x. Anyone know where an informative thread is about how use microscope for inspection. Views on such?
You want about 200x so you are on the right track. Up in the turntable forum stickies there is one for DIY somethingerother (... DIY Projects & Setup Info) Click it and look for Sparkys thread on diy stylus scope.
Briefly checked that Sparky sticky thread. Have good start with scope. Need a 20x eyepiece for 200x mag. A way to hold stylii and some lighting.
Years ago, I worked where where we inspected the geometry of drill bits useing a special microscope called a Mohawk. There too, the halogen lamp was on a gooseneck to get just in right spot to reflect facets of drill points. We also used white cardstock like a photographer does to reflect soft light.
Will be nice to have soom idea wheather my old m95ed etc are safe to use.
Ditto on the eye piece as JP indicated. You'll need to fashion the lighting aspect of the scope if you are truly going to get to the wear patterns on the stylus otherwise you get a "better" view of the stylus than your eye or a loop but it will provide no help on the wear level.
The eyepiece is likely to cost you considerably more than you paid for the microscope. You will probably have to hire it out to recoup your expenditure. :biggrin: It would also be nice to take photos of the stylus. There goes another $1000. I hope you have luck with your endeavors.
