I was a young teen when the Z100 came out and I thought that it was overly complex and I really didn't like it.
Now that I've seen a linear tracker that didn't work very well and how bad inner groove distortion can be, not
that I think it will solve IGD, I got very curious to try one. One came up nearby at a good price that looked to
be in good condition and I bought it. I probably should have gotten the SB version but I'll just give this away
if it doesn't work well enough for a second system.
It is very clean, just a minor layer of dirt dust on it, the dust cover is decent with some scuffing that I hope will
rub out. It is a changer and says Zero 100 without any letters.
A friend referred me to this changer repair manual:
https://worldradiohistory.com/BOOKS...-59-Servicing-Record-Changers-Mileaf-1956.pdf
It came with an LRE Phase 44 cartridge which is a Pickering (XV-15) sold under a house brand and the stylus
is white without any identification on it.
None of the grease had hardened, it might have been worked on in the past, who knows.
Several have suggested to replace the motor mounts but they look so good that I'm going to leave them for
now. The idler looks good but is glazed over, tried to clean it up a bit with sandpaper but not much better, it
probably needs a new one from VOM.
REPAIRS:
There's a rubber o-ring at the bottom of the platter spindle bearing that I've seen on other Garrards and is
always disintegrated as is this one. My friend tells me there's another one below the spindle bearing race.
I'll have to look into how to replace these.
I watched this YouTube series which mainly says to remove the old grease and apply new, oil where needed:
TESTING:
On the first test it ran in manual mode but the speed was not steady and changing the speed from 33 to 45
seemed to help, then the speed would hold for a bit.
Tried automatic mode and it didn't engage, then after a few tries it did but the rotation stalled. Checked the
idler and it seems to be too hard to grip and run it in auto mode - probably need a new one.
REPAIRS:
TESTING:
