gasket purchasing
djcslice
where do i buy replacment gaskets for ar-14 woofers? does anyone know if the ar-14s had a sealent puddy on the box? supposively some ar speakers had it but i am clueless to which ones.
It's called Mor-Tite & you can get it at Home Depot or Lowes.
Even if it didn't have the caulk originally, using Mortite to seal a speaker basket to the box, is a good idea on most any speaker. Unless there is already a rubber or foam gasket in place, I'd go ahead and use it.
As for gasket- I can't remember what size an AR14 woofer is. If you want to send me a PM with the woofer size, I probably have the cardboard gasket you need...
Regards,
Gordon.
