Gear needed? Vinyl to CD
6bang
aircooled
This issue has probably been hashed thru before here but...
What gear do you need for turning your LP's into CD's?
I have a turntable of course and computer with burner but I'm thinking I will need some sort of analog to digital device after the TT and before the computer. I know I am missing something here but what is it?
What gear are the rest of you using to turn your LP's into Disc?
What software do you use?
What results have you had and do you like them?
My Rega P2 is plugged into the TT input of my NAD integrated amp, which , in turn, is plugged from the tape-outs into the sound card of my computer. I use Audio Cleaning Lab 2004 from Magix. It does some pop and click cleaning. My standard is that I want the music on the records on a CD. I am grateful to be able to play the CD-Rs in the car or home cd players. Absolute perfection, while nice, is not a requirement.
Have fun.
All you will need really is a 3.5mm stereo to RCA connector to go from the rec out on your receiver, stereo, preamp etc, to the Line In on your sound card.
For software I like Cool Edit 2000. now taken over by Adobe, under Adobe Audition. There is some more powerful tools out there but cool edit is simple and probably what you will want.
Once its all set up, make sure you adjust the "adjust to zero-DC when recroding" in Cool Edit settings to make sure the level meters are accurate.
Also keep watch of the gains, you don't want any clipping, try to keep it about 2db down from peak, and if clipping occours at anypoint turn them down for best results in playback.
My humble apologies
botrytis said:
Do a search first - before asking any questions. This topic has really been discussed previously.
Dave
You are of course correct sir.
My attempt at a search before I posted was inadequate. It was However tried. My apologies.
Perhaps you could direct me to a thread ?
Some software have wave editors where you can edit the recording afterwards if you so chose. It may seem like a good idea to equalize a bad recording, but from my experience it is best to leave a recording at a flat response. You can always adjust tone controls later on playback if need be. :smoke:
As with everything digital, garbage in = garbage out.
That being said, the nicer equipment you use from the cartridge to and including the soundcard, the better your cd will sound.
After several years, many upgrades and dinking around, I have a pretty nice system for doing this.
A Pioneer PL-55DX equipped with an Audio Technica AT70 cartridge (their best spherical cartridge...and for some reason, sphericals seem to run a little 'quieter' on questionable records) is fed to a NAD Integrated Amp, which serves as the phono preamp. That in turn is fed to the breakout box of a GINA by Echo sound card (It has a physical external box for inputs, outputs) and is recorded in Sonic Foundry SoundForge 6.
I try to keep processing to a minimum. I use the default "Remove Clicks and Crackles" setting called "Default for Vinyl Records" from SF's noise reduction package.
I record each side as a single track, and then run the noise reduction. Then I break each track out by cutting and pasting it into a new track, and completely remove all information up to the very first note on each track manually. On the tail end of each track, if it's a fade ending, I fade the tail part of the fade and then mute the track up to the start of the very next track. If it ends cold, I'll do a gentle fade on the sibilance or room ring, and do the same...mute information after that up til the next track start. This insures that there's absolute silence between tracks, and the NR gets most, if not all, of the clicks during the song. The result is about as good as it gets.
As always, there's room for improvement, but if you get a decent phono pre-amp, a decent turntable and cartridge, and a very nice sound card (this is the hardest part, most of them are junk), and the software of your choice for cleanup (and under-processing is preferred to over-processing), you'll do well also.
Not mnetioned, how about a CDR?
Have never gotten around to using this computer to burn CD's from Lp's. Not a major priority around here. I got a Sony CDR and hooked it to my tape monitor loop. While not as good as burning it through a computer its suits me, for now. The only problem is if you have a crappy LP--you will have a crappy CD :thumbsdn: Since I spin Vinyl most of the time its not a big deal. CD's are for the car and friends. Not a big priority. Its harder to hear a pop or hiss in the car.
Even with all my upgraded "Vintage" stuff CD's sound pretty crappy when compared to the same thing on a LP. Only get them when nothing else is available. Good luck!
Eric
