Here is a bit of data from my set, for comparison's sake.
Just to have the info here for newcomers, I have the AE Lambda TD15M 8ohm in internal golden ratio cabinets of 5cu.f, with a bottom slot-vent totaling 190sq.cm in area, tuning the cabinet to ~32Hz.
I measured the following with the cab on its head, thus the vent was up in the air. Mic was placed mid-cone, ~1cm away, and very close to the baffle plane for the vent measurement. Vent output was adjusted by -13dB, as per 20*log(190/855).
Blue trace = woofer, near-cone
Red trace = near-vent, -13dB adjustment
Green trace = summed response
This is fairly close to simulation, with a f10 point in the mid-30ies. It sounds good in my small room.
Disregarding the fact that DT's woofer is 4ohm, the major differences are the cabinet shapes and tuning frequencies, his more squat/stout and mine taller/leaner, which I'm hoping helps give a bit of punch around 90-100Hz, as it verges on an MLTL, can't really prove this though.
His Fb is mid-40ies while mine is low-30ies. I would expect this to give stronger output from 40-60Hz versus my cab, which trades this for some reach sub-40Hz.
az
