Here is a bit of data from my set, for comparison's sake.
Just to have the info here for newcomers, I have the AE Lambda TD15M 8ohm in internal golden ratio cabinets of 5cu.f, with a bottom slot-vent totaling 190sq.cm in area, tuning the cabinet to ~32Hz.
I measured the following with the cab on its head, thus the vent was up in the air. Mic was placed mid-cone, ~1cm away, and very close to the baffle plane for the vent measurement. Vent output was adjusted by -13dB, as per 20*log(190/855).
Blue trace = woofer, near-cone
Red trace = near-vent, -13dB adjustment
Green trace = summed response
This is fairly close to simulation, with a f10 point in the mid-30ies. It sounds good in my small room.
Disregarding the fact that DT's woofer is 4ohm, the major differences are the cabinet shapes and tuning frequencies, his more squat/stout and mine taller/leaner, which I'm hoping helps give a bit of punch around 90-100Hz, as it verges on an MLTL, can't really prove this though.His Fb is mid-40ies while mine is low-30ies. I would expect this to give stronger output from 40-60Hz versus my cab, which trades this for some reach sub-40Hz.
az
That looks good AZ. I assume you can bring up the lower end a bit with placement. That is certainly in keeping with what I've seen out of the Ms.
One thing I like about the TDs is the low Le. A high Le will smooth out the signal just like the choke in an amp. A low Le lets the signal come through untouched. Much better bass and mid clarity.
The 1501FE is a great driver too.
AZ, your measurements seem to make sense. Can you remind me how your port length compared to simulation?
Did you try the type of jig that uses amplifier output? That's what I ended up using, because trying to use the output of my USB interface I got high noise and some sort of instability that would cause it to freak out and turn off. I don't use diode protection or anything, but that's because the interface only cost me $40 (used Lexicon Lambda), and I want to replace it with a 192kHz unit anyway.
P.S. My last measurement shows approx. 5dB higher bass response than AZ's even down at 30Hz (~-15dB vs ~-10dB). Both of our measurements are probably suspect in the bottom octave, though.
I hope I did things right, using RayW's technique.
That wasn't me. I learned it a looooong time ago. It was in Joe D'appolito's book on measuring speakers but I think I was introduced to the method before that.
DT, just for fun would it be possible to reverse the phase of your adjusted port measurement in the software before you add it to the woofer measurement?
Yep, can do See gray line below.just for fun would it be possible to reverse the phase of your adjusted port measurement in the software before you add it to the woofer measurement?
