Alright, it's been a while since I last spoke of my new Vandersteen 2ci's and thought I'd give an update since many of you demonstrated interest in my situation.
Just a quick refresher.....I picked these up about a month ago. Once I got them home and hooked them up to my rig (Onkyo M-504, P-306RS Integra, Yamaha 31-band proEQ, Yamah 845 CDP, Grant Fidelity Tube DAC 09) I wasn't impressed at all. Many of you chimed in with recommendations and advice...thank you....and some were curious about this/that and the other and some had questions. I've learned and experienced more in the last month with these speakers than I have in the entire 18 months I've been messing with this stuff.
First let me say this....these speakers have taught me that when you get to a certain level of performance and capability you absolutely can not expect a "plug and play and your kickin' ass" scenario. It appears to me that sometimes you have to work to find the magic of some gear....and I respect the hell out of that.
The first thing I did was address my room's reflective acoustics. I built some 2.5'x6' absorption panels/bass traps and placed about a dozen 2'x4' acoustic celing tiles at first reflection points and on wall behind speakers. Next I got my hands on some much better speaker cable than my 12g landscape lighting wire....some Audioquest Hyperlitz 3 Midnights in a shotgun configuration so I could biwire. Then I started swapping out upstream gear...which I'll report on in just a moment. But before I go there I must mention that probably the most profound change came after the room's acoustics were tamed. Now, understand this is a work in progress but my initial attempts yielded some impressive results....so kudos to those of you who pointed out that I should tackle room acoustics first. .
Now, the upstream gear. From the Onkyo M-504/P306RS Integra combo I went to a modded Hafler 500/110 pre combo. A little better detail, definitely stronger bottom end and more extended top end with improved clarity, soundstage opened up and imaging was more discernable as well. The Hafler sounded stronger and didn't seem to be working as hard as the Onkyo, but it was a tad...oh, I think the word people like to use is "grainy". Just something about it wasn't smooth. It sounded very good, but it wasn't "sweet".
Next came a DAC swap from my Grant Tube DAC 09 to a PS Audio DAC. This netted an improvement in sonic clarity but at the expense of weakness at some frequencies. For instance, the sampling rate on the PAS DAC can be switched from 96 to 192khz. The lower rate netted better mid to upper bass and the higher rate better low end bass, so you had to choose which you wanted but one of the two was going to suffer. Regardless, the Vandy's sounded great at both sampling rates and it was at this point I noticed just how sensitive the Vandy's were to changes in the nature and quality of the signal. Hmm, so this is a "revealing" speaker....interesting.
At this point the sound of the Vandy's had improved noticeably....but I still wasn't as impressed as I thought I'd be. I had just picked up some ADS 1290/2's and my friend was wanting to hear them so we threw them in at this point. The forward, dynamic nature of the ADS's made them a lot of fun to listen to compared to the Vandy's and we left them in for the duration of the evening.
After about twenty or thirty minutes with the ADS's the Hafler went into protection mode and we decided to throw in my Phase Linear 700B. This netted a very impressive result as well. The PL was so much warmer and richer than the Hafler...it really was easier to listen to the very dynamic ADS's with the PL and I kept the ADS in the rig for a few weeks before I decided to put the Vandersteens back in.
Having been impressed with the PL and ADS combo I was anxious to hear the Vandy's with the PL and last weekend finally made that happen. Well, the combo proved to be an exceptional one 'cause the Vandy's just simply started doing everything better than before with the Hafler. Seriously....you name it, it improved. But I could still hear some things lacking a bit so just for kicks I decided to put the Grant tube DAC back in. This was a shocker. I've been thinking the PS Audio DAC was an improvement over the Grant....well, that may have been the case with the Hafler but certainly not with the Phase Linear. I think I found synergy here with the tube DAC, Phase Linear and Vandy's. It's the best sounding rig I've put together yet and now consider the Vandy's my finest sounding speakers (though I have many other candidates that I've yet to try with the PL/tube DAC). The Vandy's are clearly more laid back than the ADS's, but this gives them a controlled refinement that makes everything I play through them sound very, very good. The ADS's seem to have more sonic energy you can feel (it's fun...for while), but as far as an overall sweet, warm, dynamic, cotrolled, detailed, accurate sounding speaker with exceptional imaging and a big soundstage, the Vandy's take the cake.
