MyHeresyIsMe
Well-Known Member
Too many similar buttons grouped together to easily learn then but with time shouldn't be hard to use without having to read each switch label. Long and lean does look good.
Funny about that, because I was sitting on the floor trying to see how many FM stations I could get with this 300 ohm antenna next to the interior wall of this house, trying to figure out the "FM Mute Lock" button ----OFF when in is pushed in, while other buttons in that group are ON in the same position. When I push it ON, I can't pick up other FM stations. So I reach my hand to the back panel and lift the three-way switch to "HIGH" and then the Right VU meter jumps while the Left VU is not moving. Turn the ganged capacitor a bit, switch it back to OFF and the two VUs show me the wattage and I get a station clearly. I'm sure the tuner needs an alignment ---- that's not me, but the combo of analogue dial, the digital read out, and all the buttons is an experience alright. Yes, it is 40lbs of low, long, and lean. I'm waiting for the lamps and see what it looks like with those. Should look like an aluminum Christmas tree with lights from the early 60s.
