Got a Yamaha M4!!!! But needs work
Just powered it up today and I got 633mV in the left and 0mV in the right. It came out of protect but soon went back in.
I did find out that the Pre-amp in the Kenwood KA-9100 had a problem in the left channel where it would distort and this went on before I connected the KA-9100 to the M4.
Could the pre-amp in the 9100 have messed up the left channel in the M4? Just wondering? I mean, the M4 was playing yesterday afternoon and all this happened when I was moving the amp into my main system and then making sure the offset was down BEFORE I hooked up my JBLs. The amp played for 4 hours on saturday night with the 9100 pre-amp before I was going to move it into my main system. I even had the offset on the left set to 0mV. Looks like I will take the M4 to my tech down in Seattle and have him take a look at it.
You should not even have the preamp or speakers hooked up when adjusting Offset and bias...If you are trying to measure offset with a source hooked up your offset will be jumping all over the place.
Set it correctly once then just leave it be. The alignment procedure states " NO LOAD" for bias and offset alignment that means no speakers...
Oh, I know not to have the preamp or speakers hooked up when adjusting offset or bias and I did not.
Laith, why do you insist on using that damn 9100! Its sick! Give it rest until it gets a new bill of health!
Okay, found the problem, haven't tested it out yet.
I pulled the DC balance trim pots and they were fried. They measured less than 100 ohms from leg 1 to 3.
New bourns multi-turn in place.
Oh ****, nevermind, those were supposed to be 100ohm variable resistors! It's the bias adjustment that is 4.7k
Doh!
Byrd--Tap around on the offending channels circuit boards.Sounds like a broken solder connection/wire or loose connectors..
I have it all apart until I can get the rest of the parts in, missed a couple caps in my first look over.
All connections will be polished and treated with Dexoit gold, and I will double check for broken solder joints.
Get it figured out yet?Or still waiting fer parts? I would have fixed the problem first.. before recapping the amp.But thats me.:yes:
I was going to recap it anyway, and it's not leaving here until its fixed.
Wanted to get the old caps out of there as suspects.
I am still waiting for lha1992 to OK the total and pay me, parts will probably be here on friday.
:scratch2: Well ..I guess anythings possible.Keep slugging away you'll get'r done..:yes:
Is the only way to get to the conductor side lower board really desoldering all of the T-03 sockets???
Nope. Just unscrew and remove all 4 output transistors and the CCA will drop out .Keep track of where the 2SC´s and 2SA´s go..Good opportunity to clean off the old compound and apply fresh compound.
+1 very easy to do.
Cheers,
Bob
Will, hopefully everything is going good with the M-4. Sorry for being on the other side of the world right now. I'll be back in a few weeks so.
Okay, got this all put back together.
Finished working on it last night, the thermal putty was very hard to work with, I wish the mouth of the tube was about 10x smaller so I could have gotten it more even. I ended up just cleaning up the excess around the edges rather than worrying about getting it perfect.
So now it is 100% recapped (minus the filters), and has 6 new trim pots, two each for the rail voltage, bias, and DC offset.
You just need a very,very thin coating of thermal compound < .25 mm on both sides of the mica insulator.I spread it with a single edged razor blade-First on the heatsink side of the insulator, then on the bottom side of the transistor.
Single edged razor blade... now you tell me! :D oh well, next time.
Well went to pick up the M4 from Will since its been 2 months since I gave it to him when I went on vacation and powered it on today and it WORKS!!
