Mitkraft
I bought a Yamaha CA-2010 off eBay and finally had a chance to test it on Tuesday. It was listed as "Working Unit Cabinet Shows Wear SEE PHOTOS Due To Age No Warranty Selling as Parts & Repair due to no Warranty". I expected a unit that needed repairs but was working on some level. As it turns out I can not figure out what on this unit can be construed as "working". I was prepared for some repairs but not for a completely dead unit. No lights on the unit work, the meters flick when I turn the power on but go back to zero. I've tested the pre-amp and amp section independently and neither of them work on any level. There is no other signs of life, no activity, and no noise of any kind. See the pictures below to see what I found when I took the cover off. It looks like it has been stored in a pretty rough environment for some time and might have even had moisture exposure due to the rust. It's also completely full of cobwebs.
I paid about $300 with shipping and everything and my question is this: What would you do with this unit? Is it repairable? Can it be fully restored (functionally, cosmetics I can handle) or is it likely to cost as much as a proper working one would have? I anticipate that I would need to recap any of these old units so consider that cost a wash. Other than standard stuff you are going to have to do to any unit (caps, lamps, etc.) what is it likely to cost me to repair this unit? I'm not an expert but I'm hoping that I could stumble through it myself but if extensive board rebuilding is required then maybe I'm in over my head. If a unit in this condition is still a good value at $300 then I don't mind tackling it, but if its too far gone then I'd just as soon file a "not as described" and get my money back. I did attempt to contact the seller but he's sticking with the "no warranty" position. My contention is that putting "working unit" in the ad was misleading and implied that it worked to some degree.
.....Send it back.......
