Thanks for your input, guys. While I’d still like to hear more from you Grado guys, I sent Grado a message this morning to see what they have to say. I realize of course, that their opinion could be a bit biased, but I wanted to know what they’d say.
Here’s what I wrote to them:
“Hi there Grado folks! I’m considering trying a couple of your wood body phono cartridges and have questions about choosing either the high or low output version..
I’m presently using a phono stage with many gain (and loading) options with gain up to 60dB. It’s a quiet stage at all settings I have tried. I also have several SUT’s to choose from, with plenty of gain options.
I understand that these are MI cartridges so coil mass is fixed and by itself, shouldn’t change cantilever or tip mass.
I’ll be using my new cartridge on an Audiomods 6 arm, BTW.
Which version, high or low, should I choose for highest sound quality??
Thanks, Duane”
And they quickly replied:
“Hi Duane
use a low output but make sure you can low it into a 47kOhm impedance and use a minimum of 56 dB gain
we would not recommend using a SUT as we removed copped from the cartridge, we didn;t want to add it back with a SUT
any questions, let us know, happy to help”
Interesting. Still unsure of which to order but leaning toward the LO version. It’s really not all that low anyway, at 1mV output; right?
