H.J. Leak Speakers-$100.00...CL/Las Vegas
Not white van! Those are pretty rare, and very sought after. $100 is an absolute steal by the way! I've seen a few over here on ebay going for 10 times that. Run!
Very efficient and extremely well made.
I just emailed the guy, I would have to make the 4 hour drive from SoCal to Vagas but I think they would be worth it.
And you can stop at the Bunny Ranch on the way back. Or swing on up to Mammoth for some skiing. Ah...I miss OC road trips.
A very serious speaker, and I believe the woofer is transmission line loaded. But the styrofoam/foil sandwich woofer is heavy and not well balanced so tends to sad on the suspension, and so stop working. Rotating it 180 degrees might do the trick, in which case you'd have a major deal. Otherwise, its a hassle to repair, but still probably worth it.
