:yes: WOT, I'll definitely share more once I get going on it, an "up the skirt" shot sounds fun, lol.
ALWAYS up for those LOL.
Here's some shots of my H/K A260 modifications:
-Mcshane'd power supply (revised rectifier with "stacked" 2x 820uf ultra low ESR caps in the doubler, JJ 2x100uf, and CP Manufacturing 3x40uf all mounted top-side)
-Totally rebuilt and reloated bias generator to achieve minimum -40VDC (you can see it on the far left of the under chassis shot)
-Total recap of ALL coupling positions -Russian K40Y PIOs(4), Mcap Supremes(2), Auricaps(2), 716P Orange Drops(2), Hovland Musicaps(4)
-Individual bias pots with 10 ohm cathode resistors
-Top-side bias test points with rotary switch
-Triode<> Pentode Switch (added 200ohm resistor to screen for stability)
-Added new RCAs for AUX1 AUX2 and Mag Phono (after photo obviously)
I basically removed the two stock 5K balance pots, and installed the triode switches in those empty holes, then drilled for the Bourn 10K multi-turn pots, 5-pole rotary switch (to cycle to each tube's cathode circuit) and DVOM test points so it's easier to adjust your bias.
Normally I dont like drilling the top-plate of the chassis for stuff like this and often use the back of the chassis, but I wanted to make it easier to adjust/set bias from the front while on the audio rack (so switching between Triode-Pentode & re-bias could more be easily accomplished). I use a plastic television adjustment tool to reach in between the tubes set the bias.
By the way I've made similar mods to an A250 as well, with equally good results (but with a few minor changes)
If you (or anybody) wanted more detailed information on these mods either post here or PM me
WopOnTour
