hack dcm tf 1000
I have TF-700's and one of my spring clips broke. I took a pair of pliers and gingerly broke the rest of the spring mechanism off of the connector plate. If you look closely where the spring clips meet the base you can see that it looks like it is melted together. I broke that entire section off. After it is out of the way, I drilled holes and used binding posts to replace them.
I used these from Parts-Express
http://www.parts-express.com/dual-binding-post-1-red-1-black--090-475
Go slowly, take your time - it shouldn't be too much trouble.
While you are there, may as well replace the electrolytic capacitors in the crossover.
One of the ones I had shipped in last year apparently got slammed and the crossover mounted to the back of the terminal plate broke loose. I did a lot of work using JB Weld to rebuilt/repair the plate, plus mounted a pair of decent 5-way binding posts instead of those god-awful spring terminals. MUCH improved!
attachment.php
Another congrats on a great find. I would suggest that you remove your email address. Posting addresses are a sure way of getting your email hacked or spammed. Just use the AK private message system.
