Hammond AO-35/A0-29 Bass amp project
Hello,
I have a Hammond Ao 29 and Ao 35 tube amp chassis I pulled from an organ I've gutted. Theyre complete with made in holland RCA tubes. I would like to use one or the other to make a Bass amp. I dont play guitar but I would love to make my own bass amp. Besides the amp and tubes, I grabbed the speakers as well. I still have the unit in the van so I can pull the on/off switch to reuse that for my project. I also have a dead SWR working man amp I can salvage an input jack, fuse holder, and possibly the potentiometers.
I want to ask a little help with what spec volume/tone/bass controls I need to source. Does the whole tone stack (vol/bass/tone) go inbetween the first and second pre amp tubes?
I want to use the AO 35, as it seems more straightforward. Its a 6bq5 PP amp. Surely this can handle being a bass amp? Or am I better off using the AO 29 with its 6v6 PP configuration?
I imagine the guitar amp conversion right ups will be my mirror save for some bass specific discrepancies, and what those differences will be ie (what I need to change to be a bass amp vs a guitar amp conversion)
Output transformer. I already have seen mention in the guitar conversions the stock Hammond might not fit the bill, and others say its fine. Any suggestions?
Any chance on reusing the rather generous Hammond speakers? Or should I put a nother 1/4 jack to go into a cab?
Thats it for now, the Hammond was free and very complete. Scored a lot of good tubes and components so I want to make something with it. Cheers :)
Here's some "tone taste" videos of the amps and tube types we've been discussing here. Any 6V6 guitar amplifier, and any Ampeg fliptop, is tone heaven.
They aren't real loud, so you use them to get the tone, and then mike them through the PA.
If you wanna sound like these guys, ya can't go wrong with these amps/circuits, haha:)
The guitar amp is a 6V6-powered Fender, probably a Princeton, and what I've always referred to as the worlds best sounding 20 Watt distortion pedal.
The bass amp is an Ampeg Portaflex. The model is uncertain as I can never get a close look, but the faceplate indicates either a B15N (Thiele cabinet) or a B15S.
In any event, they are both being pushed well into distortion;
I used my AO29 for my guitarist rehearsal amp (with a 2 x12 cab). I think I just wired up a volume.
It seemed fine. 6v6 PP, 12ax7 input. If I changed the wiring, I copied a 6v6 fender.
Power transformer and output transformer are stamped AO...
I can attach pics if needed
