CHATRITOR
cattoo
Tough luck recently, most have closedShould be some stereo shops in hk that can look at the needle and check for wear.
Atleast I cant find any
If I can find a retipper I'll try it I guessWe got our beloved DENON DL-110 rebuilt with a boron cantilever and an even smaller nude diamond elliptical stylus.
It now easily challenges the more costly carts we own! (SHELTER 501/2 and DENON DL-103R...)
If I was starting again, I wouldn't hesitate to spend $US200.00 on a brand-spanking DENON DL-110 - look after it and enjoy the 500-hours of replay the stock machine offers - then get the rebuild.
You will never regret it!
Ill try the EL when he comes back and i'll see how it sounds to me!Upgrade, when it needs it, with boron and a nice ML or Shibata tip would make that Hana a super cart. Though I love MM carts, you'll notice a definite audio seperation with the Hana and would match that preamp you already own. I'm voting for the MC. BTW, with reputable retippers, the boron w/ML is coming in cheaper than just a retip.
we both have the stock technics headshellIt sounds like you have a good, pragmatic grasp on the situation. If it would be an easy matter to try the cartridge out, eg if both you and your friend have turntables with tonearms that share the same replaceable headshells, like SME/Technics, then you could try to cartridge on your turntable, without any major surgery.
Why elliptical nude? No Shibata or microline on the 110?
)@CHATRITOR, thanks, what effective mass does Jelco give for that arm, do you know?
ry interesting actuallyI'm in Mainland China. Have a read of this... might help you out on this decision!
The Tale of the "pimped" DENON DL-110 High Output MC Phono Cartridge!
(Hope nobody minds...)
sondek is correct, its around 13.5g@CHATRITOR, thanks, what effective mass does Jelco give for that arm, do you know?
Very interesting actually
Do you have his address or contacts? I could reach out to him and see
Also, I see a very popular upgrade being a wooden body for MC carts. do you think that's needed or overkill?
SKYANALOG INTERNATIONAL CARTRIDGE REPAIR
As for wooden bodies for carts, there are other things to try before shelling out that sort of money.
Worth remembering too, that with all these things, there is no one right answer... just people with opinions.
We now run our DENON DL-110 with "cheeks!" So there is another opinion!
I'll post a photo soon, if I can!
Interesting, of all the cartridges I've had in play the microline is the very quietest in the grooves(silly quiet, actually), while the ellipticals in my case were the least although still nothing objectionable.my priority then becomes an ultra-quiet ride in the grooves!
Amen to that, amigo, amen......your ears are, in the end, the only opinions that will matter a great deal so best to listen to what they "say!"there is no one right answer... just people with opinions.
Back to the original question: I believe you will be well-served to get your friend's Hana and put it on your arm and see how you like it. That's really the only way to know and I hope you'll let us know what you think?
)I understand what you mean exactly. I decided to listen to a Rega 25 for a while and mounted a AT125LC I had for years. Although there was the clarity, detail, etc., it had that clinical AT sound that was more Compact Disc than anything. I decided to try an older AT14Sa I had and removed the AT125LC. The sound was more along the lines of the best of a V15 Type V but terrible with the noise of the grove that the Line Contact did not have. The AT14Sa is a Shibata and I even tried a brand-new stylus I had with the same results. Part of the problem was I could not raise the tone-arm to get the correct VTA. Last night my son installed a Goldbug Clement II I have and loaded it at 90 Ohms. I think it has found a home for the moment. The cartridge playing height at 1.3 grams was suitable for the Rega tonearm. Quiet and toe-tapping!I've never used a SHIBATA or a MICROLINE stylus, and I've heard good things about performance and stylus life.
But equally, everyone seems to agree that these two special profiles ALSO require absolutely perfect alignment, whereas the good old elliptical is a bit more forgiving.
In a world where all too often brand-new cartridges arrive with slightly skewed cantilevers, I think perfect alignment is an unattainable pipedream.
Besides, if ELLIPTICAL, SHIBATA and MICROLINE all sound fantastic, my priority then becomes an ultra-quiet ride in the grooves!
Our elliptical styli offer just that! Utterly silent on pristine grooves - and fairly quiet on worn LPs too.
BTW, I've never owned a stylus that has worn-out. Fate always interferes and toasts the cart in some other way - so I'm not too bothered about (alleged) extended stylus lifespans.
As far as I am concerned, if the elliptical sounds fantastic, is more forgiving of set-up (and therefore), quieter in the grooves - and costs WAY less - I can re-tip every 300-500 hours and I'm way ahead.
So, I'm ELLIPTICAL all the way!![]()
Hahahaha! Thank you for the compliment and yes, I've been called a lot of "worse" thingsBTW... Fishead, did anyone ever tell you you look like HARRISON FORD GONE FISHING?
(I bet you've been called worse...)
AND, nobody has ever pulled a sword on me!!!!Ahhhh.....now that's what it should be! Happy listening, amigo.....Quiet and toe-tapping!
Just did, confirmed everything with him and the cost for a boron + EN stylus is $225 (1650 CNY, exchange rate should be approx that)Best to ask these question of Aaron, at SKYANALOG.
BTW, why not package well and let China's incredible courier service do the hard yards for you? It costs peanuts and everything is delivered with a phone call.
I recall our turnaround from Aaron - who is bloody miles from our home in Hangzhou - was only about 72-hours including the repair!
Have a chat with Aaron - in English - then just sit back and relax!
Seems good to me, I really wish someone in Hong Kong can let me demo the dl110 so I can test the sound once first
My styli is very worn so it’s only a small fraction of the potential, I want to experience it at max at least once just for safety
