bluepine27
Hello, all
I have a pair of Lafayette 1003 speakers that I changed out the caps in and wanted to swap out the tweeters as well. It’s not for me but for my friends as a thank you for recording with me. I refoamed these as well so feel pretty invested but feeling a lil hopeless on this tweeter search.
the back of the cabinet said these are 2 1/2 inch tweeters so I didn’t measure it and scooped up the T-25 2 1/2 tweeters from Parts Express and these ones are a good bit bigger.
Lafayette’s 2 1/2 inches is measured from the inside edge of the screw hole to the inside edge of the screw hole across from it.
The Parts Express 2 1/2 inches is measured where the cone flattens out on one side to where it flattens on the other side
basically the width of the whole tweeter can’t be more than 3 inches. The parts express tweeter is 4 inches.
Bottom width of the Lafayette speaker is about 1 3/4 inches
I think I would rather save these tweeters for something in future and find proper fitting ones for these Lafayette speakers. The default tweeters I kind of messed up while fixing. I think I very faintly blew one of them. Sounds just a lil duller than the other and the other I ripped the cone just a tiny bit while putting the wire clip on it. This one sounds a tiny bit hissy but more full and detailed I think. Just would like to get them to be the same.
Any leads that aren’t crazy expensive would be appreciated. I tried some sites and can’t find anything that would probably fit
