It can be a bit of a head scratcher interpreting the service manual but after hooking up 8 ohm 50 watt resistors to the speaker terminals, I turn it on and let it sit for 15 - 20 minutes to allow everything to warm up and settle down. Then the signal generator gets hooked up to AUX with a 1000 Hz 0.5 volt sine wave setting followed by the scope hooked across the same speaker terminals as the resistors are hooked up to.
Since I don't know how or if I can adjust the power output on my generator, I have the volume control on the receiver turned right down and slowly turn it up until I see clipping on the scope. Then the required VR gets adjusted to equalize the clipping on both the positive and negative waves. I don't keep the volume knob turned up too long as the resistors do get hot.
To adjust the idle, or bias current, I like to use two DVM's instead of the scope and hook them both up to the indicated emitter resistors and adjust the VR's so I can read both channels at the same time. I don't think the B2 has test pins for this purpose so you'll have to clip straight to the indicated emitter resistor. Mini grabbers come in handy here. (630 Twin shown on dim bulb before being switched to full line power)
Resistors used.
