The adjustment pots do look to be of decent quality, however, they do appear to be "open" vs sealed. If you have doxitt, you could try and spray some on the wiper of it and turn it back and forth a bit, then back to where you have it set. This MAY help you determine if it's just the trimmer or some other issue exists. Best solution is to replace both with modern sealed Bourne's or similar trimmers.
