Hi!
I just picked up a Harman Kardon A-30K, the kit version of the A-300. It works but someone replaced the power transformer from a 110V primary to a 250V but in doing so he also replaced the doubler circuit with a classic half wave rectifier fed from a 250-0-250v secondary winding. Only problem is that we only have 230V mains here so the secondary is only putting out 210V giving me about 290V rectified and only 270V under load when the amp needs about 350V to work properly.
Now my question is what would be the best option :
-Reinstate the doubler circuit and find a power transformer with the original specs (as they're not indicated on the schematic, does anyone have these ??)
-Find a different power transformer with the correct primary and secondaries to keep the actual rectifier circuit ?
Thanks !!
Thanks !!
