I just received this amp and want to give it a listen before I start the restoration. As always, I first checked it on DBT, no shorts. Then DC Offset... both channels were over 100mV...hesitant to hook to speakers. Then check Bias IAW the SM to see if that could be affecting the DC Offset in any way (doubtful, but always good to check/set anyway). That's where I'm a little stumped perhaps. IF the SM is the correct procedure (assume it is) it's a real PITA to get minigrabbers on the legs of each resistor mentioned (especially the lower legs due to the main filter caps being so tall. Also, the nice ceramic leg protectors leave very little metal exposed for the grabbers to grab. So, I'm not positive that I got a good connection. However, if i did, it was not pretty... 70ish mV DC on each channel and the trimmers didn't appear to do much for the time I was comfortable leaving it on. Will reattempt later today. Could the SM be incorrect? I find it hard to believe they would make it this difficult to attach a multimeter for a routine adjustment. Can anyone confirm from the pics added if I'm doing something wrong, or if there's another way to get an easier measurement location?
