McScottlee
Hi all, I need some advice and guidance.
I have an HK A300 stereo tube amp.
Presently the output tubes are biased throught the 12AX7 tubes
I want to split the 4 output tubes from the 12AX7 preamp tubes to allow me to individually bias each output tube (orignal Schematic of section attached)
1. Is my proposed wiring diagram correct and functional? Attached
2. I could use some help in determining the R values and wattage rating, and the C values.
I see some tube specs provide a rating for the resistor, there is none provided on this tube spec.
I assume I need to calculate it. I estimate is at 143 ohms. 21.5 vdc / .15 = 143 ohm for each R, correct?
I've researched and researched, but only confused myself by finding lots of contradictory information.
I would really appreciate some help determining the correct values and an explanation of the calcs, or a few links to some explanations you know to be accurate so I can learn.
Misc Notes:
I will have a separate transformer wired to provide regulated 24Vdc to 12AX7 heaters
I estimate that the 12AX7 tubes are providing 143.33 ohms total resistance
Resistance and voltage drop was measured from OT center tap to pin 3 of each 6v6GT
The amp is powered via a 117Vac bucking transformer at all times
This is a Harman Kardon A300 stereo tube amplifier from the 60's
The output tubes are 6V6GT EH. Spec sheet attached.
My specific BIAS readings are attached.
The output section of the schematic is attached.
My proposed design schematic is attached.
The datasheet for my output tubes is attached.
Thanks in advance
Misc Notes:
Thanks in advance
