notabot
Hi,
I'm very new to tube audio and I'm feeling like I'm in over my head. I learned how to swim with my father throwing me into the deep end of the pool, and that's stuck with me ever since. Anyway, I can't find anything about this issue even after extensive Googling (probably not using the right terms or something).
I bought an HK A300 on eBay. The pictures on eBay showed all tubes and cans installed. When it arrived, in the very back, in place of what should be a silver tube-like object, is a hole in the chassis that is sealed with a piece of metal. I've found that these metal tubes are called "cans", and this specific can is called an insulated or "hot" can, and it's wrapped in cardboard due to its high voltage. Well, it would be if it wasn't missing. I think it's supposed to be part of the power supply? I get dizzy when I look at the schematic.
Here is a picture:
I'm still waiting for the seller to respond and provide more information, but I'd like to know if I'm hurting the amp by using it while this piece is missing. I read somewhere (at least I think I did) that the modern equivalent to this can would be installed inside the chassis, which could explain why there's nothing there on the exterior. I'm too green behind the ears to open this thing up right now, though.
I've been using it intermittently over the last four days. It sounds great and it hasn't exploded yet. No weird noises; no smoke; just groovy tunes.
I'd appreciate any other insight or advice. Thank you!
Here is a picture:
