Hi Group,
I generally repair solid state gear so I'm not totally in the dark, but unfortunately for me, I have been asked to fix a Harman Kardon A700. When I received it the first time an e-cap in the power supply literally exploded. So I recapped the power supply and replaced the two diodes and ceramic caps. Someone else recapped it previously and all the film caps have been replaced. They didn't bother to get the right caps and just paralleled two caps to get a close uF. ie two .1 instead of a .25. Anyway, it also got two new JJ 7591's. It worked for about 2 weeks.
It was returned to me with a blown fuse. I had the power and driver tubes tested and 2 tested bad (one power tubes the JJ and a 7199 driver tube) all in the same channel. I find a 3.3 Ohm 5W resistor shorted in the power supply section. Maybe I missed it the first time? I replace it and am supplied with two new JJ tubes. That channel now red plates one of the tubes. The other channel has old rca 7591's that test good but like 70% on the tester. I replaced the coupling caps for the power tubes and driver tubes. Still red plates. I swapped channels with the power tubes. The old RCA don't appear to red plate. The JJ's seem fine in the other channel for the short time I had it on. ie minutes. This is when I hooked my scope up to it. I am seeing a small 60ish hz in the "bad" channel. The other has similar hz but even smaller amplitude. Is this causing my red plating issue? I'd assume I would see nothing on the scope like solid state, but I never hooked a scope to the output of a tube amp. All my testing is done hooked up to a pair of 8 ohm 200watt resistors if that matters.
I would assume power supply caps but they are less than a month old and its not the same amplitude signal in both channels. Tonight I intend to swap tubes all around and see what difference that shows me on the scope.
So the question is will this 60ish hz cause the red plating or should I be looking elsewhere?
