I don't think H/K has faults with these burning... Did I mention it still works and sounds good?
Well, I don't want to be a "trouble maker" in this thread. I have a few HK's of this period (680i, 380i, PM640 among others) and I appreciate them.
I have nothing against the HK philosophy to built amplifier stage with no current limiter circuits, as long as the minimalist protection components (fuses and/or circuit breakers) trig off before the power amplifier stages blow out in your face... and in some circumstances blow out the speakers also...
There is numerous threads on AK about blown output stages in HK amplifiers and receivers. They just didn't had the "second chance" you have with your unit.
In some threads, I suspected that the drivers were the major failure cause in them. In many amp stages, the power transistors fail in first, and after they failed the drivers may fail also. This "domino like" destruction is so fast that it is not easy to prove wich stage failed in first. Circuit analysis and transistor's data sheets are your best indications for this.
In the HK, the drivers are the weakest point in the chain. They get so hot that HK chosed to mount the Vbe multiplier transistor on the driver's heat sink instead of the power transistor's heat sink, like it is in many amps. There is a very small power dissipated by the Vbe transistor, and this one was cooked by the power generated by the overheated drivers.
I said this thread is interresting because your pictures show that the drivers were very hot, enough to burn the pc board...
I thank you very much for your nice pictures, especially the first one.
Do you think it is a normal operating condition for a transistor?
Do you want to rebuilt your amp as strong/weak as the original, or do you want to improve the reliability of your amp?
