Harman Kardon Speaker ID?
brlin
Need help identifying the following speaker from HK. Any thoughts?
Model Sixty
TOTL
Designed for HK by Dr Floyd Toole
Quasi transmission line cabinet
Vifa/Scanspeak drivers.
Retailed for over 3k.
Never heard a pair but hope to soon:).
Listen
Tubed,
If you care to hear mine, I'm in Long Beach.
Design: 3 way tuned port, Frequency Response: 30Hz-20kHz(2db), Sensitivity: 90db/1m/2.83VRMS, Min. Power: 10 watts, Dynamic Power Handling: 200 at 10% clipping, Nominal Impedance: 6 ohms, Low Freq. Drivers: Twin 200mm graphite/polyprolylene cone, urethane suspension. 32mm Hi-temp voice coil on aluminum former. 450 gm encapsulated magnet. Mid Freq Driver: 76mm polymer impregnated dome. Special 240gm magnet. 76mm Hi-temp voice coil. Ultra wide dispersion design. High Freq Driver: 19mm aluminum alloy dome. Aluminum former, less than 3g moving mass. Ferofluid cooled Polymer suspension. Crossover:: 500Hz Linkwitz-Riley/2.8kHz Linkwitz-Riley. Dimensions: 50"/18.5"/11.5"(H/W/D). Shipping Wt. 100lbs.each.
