Has this Maggie bought the farm? (sorry, Bob)
Moonwatcher
Hey, tube guys . . . so my Magnavox 9304 console pull was severely jarred during a move. After just a few seconds of being powered on, it made a loud, scary rattle and the tubes sparked (see below). I quickly pulled the plug. One modification that was made was adding Edcor output transformers--but they have been working fine for years.
I took it to a local guy who repairs vintage solid state and occasional tube units. But after looking at it, he felt he was out of his depth (and doesn't want to be electrocuted).
Does anyone have any idea where such a problem could start? The big can capacitor on top? I have changed out all the tubes--el84s (7189) and 6eu7s. Thanks in advance for any suggestions!
Look underneath for any wires or leads that got shortedd to each other.
If the noise is in both channels, look real close at the power supply area.
my Magnavox ...... was severely jarred during a move.
DOH! Sorry to hear.
Any additional details on 'jarred'? Sometimes details help point towards solutions.
Pics please?
Yes, bottom cover removed, and any specific damaged area.
Was it just the one tube that 'sparked'? (FYI - never seen that before....). If no other clues, I am starting at the one tube & tracing the path.
I don't think severely jarred would cause a can cap to go bad. Maybe some wires touching together from the jarring?
Thanks, I will look again, but the amp was worked on by a competent tech about five years ago and seems pretty clean underneath. Some solder joints could probably be cleaned up.
Believe it or not, the noise is not coming from one channel or another, because the speakers are not even hooked up. It's the amp itself that makes that rattling sound you can hear in the video.
You have to watch for it, but you can also see a brief spark in the third el84 tube on the right channel. Changing out all the tubes made zero difference.
Did you change out your rectifier tube?
Pics please? If the transformers haven't failed everything else can be fixed easily
More pics coming tomorrow, Gadget. Thanks!
DOH! Sorry to hear.
Several years ago I changed out the rectifier tube. But that's a thought: the rectifier was bent way over after the amp slid off a shelf and hit the floor hard. Maybe something underneath was damaged in that incident. (It's extremely heavy because of those Edcor transformers.)
DOH! Sorry to hear.
Thanks, Mssr. Jalousie. I will look again when I get the amp back, but things look pretty clean under the hood. Some soldered joints could probably be improved on.
Me too--and pretty much everything else he ever did. (Did they change something about replying to posts? It keeps
Hehe. I can't help with your question, but I heard Maggie's Farm on Underground Garage in the car this afternoon. Love that song.
I don't seem to have the hang of the new way these chats work--my replies keep disappearing ... and then duplicating. Sorry.
a shorted rectifier could be causing this, luckily 5U4's are pretty cheap. Still some pics to rule out obvious damage would be good, then test it with the rectifier out.
also you really shouldn't run amps with no speakers connected. It can cause the tubes to arc or damage to the output transformers if something is trying to make sound and the amp is not loaded. It should be connected to a dummy load if you don't want to risk speakers.
Let's see the bottom side. It could be that feedback was reversed on one channel but holy cow, if that sound is coming from the output transformers themselves, do not turn it on again until the problem has been resolved.
apples and oranges, but recently, my kitten "jarred" one of the EL-84s loose on my amp, causing almost exactly what you described. in my case, since my amp is ss rectified, it took out a couple resistors in the rectifier circuit, which were easily replaced. I suspect that the recommendations to replace the rectifier tubes or the associated filter caps to be not far off the mark. take off the bottom cover of your amp and let's see the innards. Those Maggies are dead simple and it shouldn't be too hard to spot any singed resistors or caps.
