I know they stopped making DAT recorders, but I thought they have parts. I mean they kept making betamax tapes long after the format died. The shipping cost is a bit much for broken decks, that's all. I live in Australia so it's at least $110 for shipping.I think they stopped manufacturing DAT at least 15 years ago. So you have to be very lucky.
You can directly ask Sony but imho the most efficient solution would be to do it the Sasi's way: collect faulty machines at bargain price and use the parts.
Don't you have second hand market for dat in Australia ? (Ebay, classifieds...)
It will be probably easier to find parts for the professional line but why don't you ask Sony or above dealer ?
I found some brand new RF amp but for other models, the cost is ~160-180$:
https://www.servicesplus.sel.sony.com/sony-parts.aspx
That's what I think the problem with mine is. I just need to change the capacitors.Another very interesting article about dat but in german:
http://www.hifi-forum.de/viewthread-220-21-1.html
Apparently RF amp are a common source of problem. A guy was able to repair one by changing some capacitors.
I've already paid $180 for DTC-750, I'm not buying another one because someone claims theirs works. I'm now convinced that the DTC-750, the 57ES and the PCM-2300 all have the same issues.
The bidding on that could go up a heap, to more than I'd like to pay and if it too has a faulty RF amp, I'm stuck with 2 DATs to repair.You can add the 670, 690, 59ES as they all are very similar.
I own 2 x 55ES, 1 x 690 and 1 x 59ES. 3 of them needed a mechanism cleaning/repair but only one had the RF amp issue.
The 55ES has a slightly heavier mechanism with no belt.
The 690 and the 59ES share the same mechanism. The main difference is a bigger power supply on the 59ES.
If you have an opportunity to test the one on Ebay it could be a bargain.
The PCM-R300 share the same mechanism and RF amp with the 57ES (same part number A-2001-587-A), I am not sure it is more reliable.
Btw improvments over the 57ES are: "better designed boards", "XLR Inputs and Output connectors", "defeatable SCMS" (http://www.datrecorders.co.uk/pcm2300.php).
That could be the reason why I have a Sony TC-D5m cassette deck which is working fine and a useless Dat recorderSony started using boatloads of surface mount capacitors at some point. On consumer AND pro gear. A lot of it is useless junk now because of it. I re-cap a lot of gear, and small jobs with a limited number of those little horrors I'll do. But some of the boards with 60 to 100 caps on them..... trash.
You NEED to know specific models to avoid those rotten caps.
I had 2 Sony 8mm editing decks. One was the original, one was the "updated" version. I popped the lid on both.... The original used ALL standard caps. The "updated" one was an ocean of surface mounts. Guess which one I immediately sold, and which one is still running fine to this day?
Sigh..... electronics are turning into 5 year items these days.
Marc
I wouldn't be so sure. Check both service manuals: the parts are the same. maybe the pro series have been serviced a few more times but have probably served more.I think the R-500 would be reliable, it seems pretty solid.
My theory is that the pro series would have been serviced a few more times.than the consumer ones.
You could be right, I'll settle for the RF amp. The mechanism is a bit jerky on rewind and FF but the main problem is the distortion which on goes away when I record and play back straight away.I wouldn't be so sure. Check both service manuals: the parts are the same. maybe the pro series have been serviced a few more times but have probably served more.
Bit expensive. It's ok, SaSi sent me a message saying he can sell me 2 RF amps and 1 mechanism, I just need to wait for him to find them. I wish he'd stated how much he wants for them.If you are able to find a NOS it should be around 150 USD. Otherwise do like me: try to find faulty units at cheap price and cannibalize them.
