cscottrun4it
Let me see if I have this straight...
Is the above headshell configuration correct?
If the headshell is facing away from you, the connection to the tonearm (H4 Bayonet) is nearer to your body and the headshell is upside down (the stylus tip is facing up), the pin configuration is like this:
Then for connecting the headshell leads...- Lower Left: Red Lead (right signal)
- Upper Left: Green Lead (right ground)
- Lower Right: White Lead (left signal)
- Upper Right: Blue Lead (left ground)
- The posts on the headshell are 1 mm in diameter
- The posts on the cartridge are 1.2 mm in diameter
(If correct, this is the craziest thing I've ever heard.
