bscepter
I've recently run into a background hum problem with my Thorens TD 145 (TP-16 tonearm/Ortofon Super OM 20 cart). After removing the headshell to invert the deck and adjust the suspension, I now have a background hum that gets worse (or at least different) when you touch the tonearm and especially if you move a finger underneath the cart right by the headshell leads.
I tried sort of messing with the connections - moving them slightly to make sure none was touching another one, and that caused the left channel to cut out completely. Then I did the same thing again, and the left channel came back, but the hum was still there. (It's background 60-cycle hum, not buzz and is tolerable but annoying)
I've heard that the TP-16 can have issues with the headshell connection getting dirty and that cleaning the female connectors with Deoxit can help. My question is, can I simply give a squirt of Deoxit right into the headshell receptor on the tonearm? Do I need to replace the leads? They look fairly tight and aren't touching each other.
