equalizeme
what happens when you change the cartridge load impedance? Use another phono input?
It means that your cable from your turn table are of a certain length and couple with an impedance that creates a tuned circuit. Because of the amplification of the phono circuit, the minimal sound of the ad hoc circuit is amplified enough for you to hear.
Make sure all the grounds are well made and the input caps are in good shape. Experiment with different placement of the TT and routing of the cable.
if everything is disconnected and you get no radio, it’s the interface created by the TT and the amp that creates a primitive radio receiver.
I tried a longer cable and that.... Maybe... Helped. I can't hear it from the couch anymore, I think. I can't go any shorter than the cable I initially had, it was the width of the TT to the amp. Zig zagging the cable so it's not straight seems to help. Changing impedence doesn't make any difference.
