[Post was stuck in limbo during the outage...]
I'm whipping the Heathkit AA-151 that I picked up a while ago back into shape. I finished the cap job last week had some time last night to fire it up and give it a quick listen / performance evaluation.
What's been done so far:
- Tubes all around, since I received the unit with no tubes. The 6AU6s and 6AN8s are new old stock from TubeDepot, and the 6EU7s are vintage that were snagged from the auction site for a reasonable price; they tested well and performed just fine in my Magnavox 8802. The output tubes are a matched quad of Sovtek EL84Ms, and the rectifier is a new-production Tung-Sol 5AR4.
- New coupling and screen bypass caps all around. 0.047uF was substituted for 0.05uF between the phase inverter and the output stage.
- New cathode bypass caps in the output stage and phono stage. I could have sworn I ordered 50uF caps for the phono stage when I ordered the power supply caps, but I guess I forgot, so I substituted 100uF because that's what I had on hand. Simulation shows the difference is negligible. I don't really plan to use the phono stage anyway, but I'll test it's performance before I'm finished.
- Power supply overhaul -- new power supply caps and resistors. New resistors + bypass cap in the filament elevation voltage divider.
In the power supply, I used a CE / AES 40+20+20+20 @ 525V can that was short enough to fit. The 3 20uF sections are strung together to make the 60uF reservoir cap, and the remaining 40uF section takes the place of the 25uF section in the original (that supplies the 6AN8s). The original second can cap (a 30+30) was a smaller diameter, so a same-looking replacement was going to be tough. In the end, I got creative with a F&T 33uF+33uF @ 450V axial cap and a terminal strip. It obviously doesn't look original, but it doesn't look particularly bad, either, and you'll never see it anyway with the cover in place.
I've let the ceramic caps be for now, but I may tackle those at some point. I also have discrete components to make replacements for the PECs in the tone controls, but they seem to function perfectly well in their stock form, so that can be a project for another day.
Attached 8 ohm dummy loads and fired it up. Voltages on the power rail were reading somewhat high, despite the unit being plugged into my variac set to 117VAC. 385V at the 360V tap, for example. This is less than 10% over, so I'm not overly concerned at the moment... but eventually this thing is going to be connected sans variac to a freshly upgraded 120V mains supply, so this is something I'm going to want to revisit when I'm done with everything else. The PT has 2 6.3V windings, one for each channel, and I have noticed a discrepancy there -- one channel is getting 6.5V and the other is getting 6.1V. I'll have to dig a little deeper into that one.
I know some resistors have drifted out of spec (the 680K screen resistors on the 6AN8s, for example), and I plan to replace them. These are throwing some of the voltages at the tubes off, but not overly so. I suspect the out-of-spec resistors are skewing the current draw a bit, thus throwing off the power supply voltages.
I set my function generator for 1KHz and hooked up the scope. I increased the input signal until I saw clipping visible at the output, and backed it off until the clip went away. Driving both channels, I measured 30Vpp, which is 10.6Vrms, which into an 8 ohm load is 14Wrms, which is what the AA-151 is rated for, so I'm pretty happy about that. My function generator is putting out 558mVpp to do that, which is in rounding error of 200mVrms, which also matches the original specs. Hey!
With the volume control turned all the way up, I am hearing some hum, which my scope tells me is 60Hz, and the typical tube hiss. So I guess I'm getting some heater supply noise from somewhere. It decreases with the volume control, which tells me it's coming from the 6EU7s. The original builder was a little sloppy with the filament supply twisting on those tubes, so that might be it if there are signal wires passing close by. The heater supply is floating on top of roughly 45V. It's the original circuit configuration -- a 150K - 33K voltage divider off the "205V source" tap of the power rail, which would be 37V if the voltages were spot-on... but as I noted above, they're not. Anyway, the hum is audible on even the Aux and Tuner inputs (I haven't tested the phono stage, which I know can be troublesome in this amp), so I have some work to do there. I've heard that doing a DC supply for the 6EU7s is a common modification on this model, but I feel like I should have a silent non-phono stage even without that.
This amp does have multiple AF amp stages, so even a little bit of noise at the very beginning is going to get magnified in a way that wouldn't be present with just a single AF amp stage before the output. The input is a little funky in that there is a voltage divider on the Aux and Tuner inputs good for -23.7dB, followed by a 27dB gain stage (the second half of the 6EU7), making for an effective gain of only like 1.5. I guess what they were trying to do there is to bring down the other input signals to the same level as the post-EQ mag phono signal, to simplify the signal path through the pre-amp. Personally, I would have been fine sacrificing a little input sensitivity to avoid putting the signal through an extra stage, but perhaps this was just easier with consideration for the capabilities of the other components that matched the AA-151 (like the tuner). My preference would be to remove the attenuator network and bypass the 6EU7 completely for Tuner / Aux, and just go right to the volume control and then the 6AU6 that drives the tone controls. I need to study the connections to the input selector switch a bit more to see if this can be done.
Volume pot was a little scratchy, so hosed it down with Deoxit, worked it around several times, and let it dry overnight. That fixed it right up. The tone pots were quiet, and the tone controls behave exactly as I expected. It's currently hooked up in the garage to my Sansui SP-1700s, and I've spent a few hours listening to a variety of music on it over the last few days, and despite the hum / hiss that's audible when the volume control is turned all the way up, it sounds very good at all of the listening levels I've tried. So, even with some out-of-spec parts, it's in fairly good shape.
