Defeño
It's amplifier day here in Boston. What that means I that I just took delivery of a pair of Heathkit W-5Ms that I ordered off of eBay about a week ago. I had been mulling the purchase of such an amplifier for a while now. Initially I was attracted by the tube cage design (I know, random, huh?) but then the more I read the more I heard that this is a very nice amp.
So I bid on a pair on eBay. Here's the original listing:
They both appeared to be in pretty nice, mostly original condition. Yeah, someone had changed the input jack to a 1/4" TRS connector, and also made the output the same. But otherwise the units look very clean. They have the Peerless 16458 output transformers. The rectifier tubes are a pair of old RCA tubes, though the tube number has worn off. The input tubes are a pair of Mullard 12AU7s, while the output tubes are a pair of Tung Sol 5881s. I'm wondering if I'd be better off with KT66s which are the original spec.
So what I'm hoping to do with this thread is a few things. First, I'll share my journey with these babies and provide some "tube porn," for those of us who enjoy rebuilds of cranky old equipment. Second, I'm hoping to solicit some advice from the electrical engineers and other knowledgeable folks here about things like replacement capacitors, tubes, solid state rectification, thermistors, etc.
I've got a mostly-completed shopping cart at Digikey, but still need to add power supply capacitors. So capacitor questions will be some of my first.
Thanks for reading along,
Kim G
Boston, MA
Where I'm currently listening to a 1968 Dynaco ST-70 with the VTA/Tubes4HiFi input board.
Initial Unboxing
Twins Separated at Birth
My Transformers are Better than Dreamworks'
Input/Output Weirdness. This is on the list to fix
The preamp plug has been changed to a switch which connects the selected impedance to the two TRS jacks to the left of the input. Based on visual inspection, I can already tell that this switch is noisy as it has a loose center connection. Question: WTF was the guy who did this thinking???
Otherwise the Back Panel Looks Pretty Good
Innards have been somewhat modified, but no thoroughgoing recap/ re-resistoring has been done
Mismatched capacitors at lower left are sure sign of quality!
Second amp has more original-looking capacitors, and one obviously newer one
First order of business: Flatten one lower cover
Flattened in No Time Flat. It's nice to have a rubber hammer and a steel plate. Wish the rest were so easy!
Output Tubes, Tung Sol 5881. Are these good? (Assuming they work)
A couple more pictures to follow, but I've reached my limit with this post.
Kim G
Boston, MA
Initial Unboxing
