Zed -- The new coupling cap values on either side of the driver stage are absolutely key to achieving good LF stability in the W4. It really is important then to use the specified values.
Dave
Decent poly is fine.
Did the EL34 version of this mod ever get published?
Thanks!!
I have a very nice pair. Nicely refreshed by a prior owner, but no Dave's mods. Figured I really need to mod it (reduce b+, stability) and I have K-horns so lots of watts aren't needed, so will probably head down the Class A Triode path at the same time.
I've had this same question for some time. I have four W4 output transformers and only one has a part # aside from 51-17. I can't see any way to distinguish between a Stancor and a Chicago.
