RacerR
I think your math is solid, but I'd still worry about unintended consequences/butterfly effect on the rest of the circuit. For instance - how would the added voltage on the lamps affect Q3? It looks like the base of Q3 is controlling the power to the peak indicator LEDs, and the base of that transistor is connected directly to the negative side of the lamps.
I think the best bet would be to find the factory spec lamp, or figure out how to match the characteristics with an LED in circuit.
I think this info is correct, but take it with a grain of salt - the original lamp specs are:
I don't think the lamps are behaving exactly like that in the circuit though, since they are only getting 7.5 volts. Figuring out exactly how the lamp is behaving in the circuit is tough (for me) because the ratio of circuit voltage to on-resistance is on a curve with incandescent lamps. Lol - I've actually demonstrated how bad I am at figuring that out - I put 12v/100ma lamps in the circuit.
I have the axial LEDs in hand already, but I'd really prefer sticking with incandescent lamps.
Still not sure exactly how I'm going to move forward here yet.
Thanks for the input - any info or guidance that can be provided is appreciated!
-Rob
Lamp: 8v/55ma Axial Incandescent
Voltage: 8 volts
Current: .055 amps
On Resistance: 145.46 ohms
Watts: 0.44
Voltage: 8 volts
Current: .055 amps
Watts: 0.44
-Rob
