Nice buy on that Lux receiver.
Good move getting on AK.
Remember: if you don't wear a mask, the audiophile virus will attack indiscriminately, resulting in consequences.
We need more freaks in this hobby so let's just concentrate on the good stuff.
Stay safe everyone!
Balls. I just received the belt, and replaced it, easy as pie (thanks swechsler) - no improvement. even at top speed the 33rpm 60hz strobe is moving quickly to the right. Very frustrating.
Hmm. well don't feel bad, assuming you get it working, that belt needed to be replaced anyway (and if not, it's a common size for many different turntables). I'd say the next step is to remove the bottom and adjust the secondary controls (again, not difficult). Instructions are here. Hopefully some deoxit on those pots combined with an adjustment will fix it.
Something of an update: I have access to a number of older model record players - an old Technics SL-5 with no tonearm, mid 2000s numark and audiotechnica that i think are entrylevel from when my brother DJ'd. anything of use here? are cartridges compatible with other manufacturers?
The SL-5's (short) tonearm is built into the cover, so you may just have missed it (If it's really missing, it should be considered a parts machine). It's a linear tracking turntable, which means the entire arm moves linearly across the record as it plays, rather than on a pivot like conventional tonearms. This section of the Wikipedia article on turntables has some more info. Technics didn't invent the LT turntable, but they certainly popularized it in the mass market. Before the Technics SL-10 (their first relatively low cost LT turntable), linear tracking tonearms were very expensive.
Numark I don't know much about, but most of their stuff was generally on the budget end. I know at least one Audio Technica DJ turntable had a really bad tonearm design; it was straight but positioned in such a way that the tracking angle would always be terribly off. Getting the model numbers of those turntables would help us evaluate them better.
There are basically two types of magnetic cartridges: standard and P-mount. P-mount was designed by Technics in the late 70s and was used on many of their later turntables including the SL-5. All turntables that used P-mount cartridges had straight (rather than S-shaped) tonearms. A few other manufacturers used P-mount as well. The idea behind P-mount was that the cartridge had a standard mass, size and terminal positions, so no real setup was required. You just plugged the cartridge into the tonearm, added a screw to hold it in place, set the tracking force and you were done. A P-mount cartridge could be converted to standard mount using an adapter (that shipped with many P-mount cartridges of the era), but not vice-versa. P-mount cartridges are still available.
