Hi all - I'm in a bind here with my Marantz 2265B. It has a bad short / pop when the tone circuit is engaged via the tone mode switch. I learned that the most likely cause is bad/leaky caps in the tone circuit. So I planned to replace the 16 low leakage caps on the tone board, and while in there replace the 2SC1345 transistors.
But after hours spent on digikey and mouser, I just cannot find the low leakage electrolytics in stock. I can use films for the 1uf caps in the signal path, but there are a dozen or so 3.3-100 uf low leakage caps that would in the past have been replaced with Nichicon UKL. But I cannot find them in the sizes I need.
I read Rubycon TWL can also be used but no luck finding those either. I also read some are using bipolar Nichicon UES, but even those I'm not finding in all needed sizes, and am concerned about what others have said about replacing non polar with bi polar.
I have the tone board pulled and am ready to go, but cannot find suitable low leakage replacements!?
Can anyone point me to where I can find a good replacement for those caps, like Nichicon UKL equivalents?
Thank you
Thank you
