spaceman
Registered Lunatic
OK, I'll chime in here I guess. A good plumber carries an assortment of those rubber washers, both hard & soft rubber, of various sizes. I believe you need a softer rubber, as the harder ones won't "form" properly to the sink's bottom. BTW, make sure there's no crud on the sink too, like old putty or such. In case that turns into a chore to find, just use the closest size you have, & run a big fat bead of silicone on the whole top side of the rubber washer, where it sits against the bottom of the sink, & snug it up good with a wrench, then make sure you let it cure overnight. Also, be sure to fully assemble the whole drainpipe, at the same time, so you know everything's sitting right where it wants to be. :yes: Good luck.
