Yeah, on second look I did make a mistake on that schem re the .047 cap. I should have placed it to the right of the spot where the new cap is grounded. Sorry if I made you blow up a capacitor.
The new cap should be grounded in the same place you have the existing cap grounded. The high voltage goes to the + end of the new cap, and then the 100Ω carries the B+ to the next cap (previously the first cap).
The concept here is that you are adding an additional stage of filtering, with just a little resistance between it and the next stage. The branches off of the filtering caps do not begin until the B+ gets to what is now the second stage. This is done simply to help reduce the ripple current.
RWood
RWood
