You can see a red button in the pic of the speaker terminals. Certainly looks like a resetable circuit breaker of some sort.
The crossovers are super-cheap which would be expected in "budget" speakers but the cabinet looks to be doubled-up panels -screwed from the inside- which I found surprising.
A number of speakers used just a cap to crossover to a mid or tweet.
The circuit breaker was used in a few different speakers. Norman used them in a lot of their speakers sometimes multiple units. Specs are probably legible on the metal box the circuit breaker is made in. The wiring indicates it is a whole speaker over power protection device with the hot red lead going from speaker input to the breaker then to the drivers.
Might help to have the info on the drivers because this should ID the maker of the drivers.
