I decided to try and extract more info from the speaker today, after it's been sitting on my floor for a while. So after a few hours of disassembly, studying for any details that may help in telling what's original, taking lots of pictures, and reassembly, here's what I have: I removed the driver for closer inspection, hoping to find some kind of mark to identify it, but the closest I got is this:
Which isn't very helpful. But I was able to find a similar looking driver from JVC:
They look way different at first, but once you look at the basket, it looks almost the same:
That was really nice to find, confirming my thoughts that the driver is original. Even the brass brackets that the wires are soldered to are the same:
I also noticed these shallow lines in the back of the front panel:
Which I'm guessing are for some part of the process of making the cabinet? And I also confirmed that the feet are some kind of rubber, as I could make a dent in it with my fingernail. Here's two of them removed:
And I even compared all the kinds of screws found throughout the cabinet. All are flathead, and they can be divided into 1: Domed top, found on the front panel, feet, and lower driver mounting. 2: Flat top, found attaching the output transformer and upper driver mounting. And 3: The ones used for the switch, which are different to the rest. I even compared a nut used on the binding posts to one from the driver:
And they seem to be the same material, and both are similarly rounded on the edges, so I think they're from the same time. Both are Metric, as well.
Front of driver:
Back of cloth that covers driver:
I doubt any more info will ever surface, but I'm still hopeful that something may turn up. Especially since this will help someone if another one like it ever turns up. And I took as many pictures as I could, that way I don't have to keep taking it apart every time I want to look at something.
