Help identifying tone arm
tjmarrone
Member
Looking for help in identifying this tone arm, came with an STD 305M deck.
Thanks, T. J.
Hope I got the pics in here
Some one out there must have seen one of these before, it is clearly not a home made thing, overall quality seams very high. HELP??? missing the anti skate weight, sure would like to know what it looks like and weighs.
No recollection of this although I suspect it came from a British-from Japan source, interesting offset tube design at the gymbal bearing interface, not seen anything like that before.
Good luck with your quest. Jelco is always the default answer.
It's an SME I am pretty sure. I was playing with a 3009 today that had some similarities but that's not it.
It has an SME-style shell and mount, but the rest of the style doesn't look it somehow. Interesting the orientation of the slot in the mount. Even the arm rest is in the SME style without being identical. I'd guess Japanese, but who?
Yeah I thought the armrest and also that black/silver part looked like the SME I saw on my friend's Thorens today. That offset is weird though.
You can see Japan printed on the base in the last picture making the Japanese guess a pretty good one. However it does look like it has some SME parts in it.
The anti skate weight isn't such a big problem, if you use a piece of fishing line from someone you might know who is into course fishing, they'll not begrudge you of a few inches of `float' line? The weight? Well, a very short piece of 1/4 brass rod, drilled through with a fine drill (put that Black'n'Decker away and use a wheel brace!!). I'd guess not more than a couple of grams but that will depend on your stylus weight? Once you've got it setup, you need a plain uncut/grooved record and the deck absolutely level, start it turning at 33 1/3 and lower the stylus onto the mid track area of the platter and it should sit there and any other area too if its setup good. finding a plain uncut/grooved `LP' with possibly be the most difficult part of this exercise, usually they were on the flip-side of a `good' test record.
Incidentally, when setup for 33 1/3, it goes awry on 45 on `some' arms.
The arm's `lead outs' are infamous for screwing with the anti-skate!! Beware, always check the `in drift without the anti-skate applied, to make sure all is well with the arm's `lead-out' wiring. It should casually drift inwards (Don't let it collide with the spindle or the records label area!!) accelerating as it goes. With the arm in complete balance (zero stylus weight) the arm should stay where you put it until you set the anti-skate, when it will swing gently outwards.
I find that when I release the cuing lever on my deck, there is an infuriating tendency for the arm to swing out-wards before meeting the lead in groove, sometimes missing the edge of the record (GRRR!!) a piece of carefully trimmed gaffer tape stuck aesthetically across the `lifter' in exactly the right place the arm is supposed to sit next to while descending, arrests it's outwards swing while the lift descends. Might not work on all decks, but worth a try?
Good luck
