angelaudio
We all start somewhere. If you plan to get into tube amp repair, take it slow with simple steps. There are a few options to get you going.
Reading up a few restoration threads here will give some useful information. That article linked by maxhifi in post #15 above is very informative and has easy to follow details on simple capacitor identification and replacement. That type of article is recommended reading before diving in with a soldering iron. I would suggest spending quite a few moments digesting that information. Replacing old capacitors is often the biggest part of what is needed and certainly a good place to start. Also, rather than trying to address every potential issue in this console piece, just take a few simple steps to get familiar, while addressing the likely major culprits at the same time. Once you have some background knowledge sinking in you can start scoping out a plan for this unit. I would suggest identifying those caps we've indicated above. Take a look at the information on the side of each and write it down, such as 0.05µF (MFD), 200VDC, so you start to make a list of components that will need to be bought to replace them. The caps are usually relatively inexpensive. The expense associated with having a tech do the work is more likely the time expended. Once the needed cap values are identified you can move on to the replacement plan. Not everyone implements replacement the same way so you might get different valid input and opinions. Decide on a plan forward, purchase parts then replace is just one piece at a time and many here can assist with how best to approach this.
If you prefer a bit of personal help, an option would be to see if there are other AKers in your drive-able neighborhood who might be able & willing to share an hour or two with you to get started. Updating your personal information with your location so that it shows under your avatar lets others know where you are. Often, a helpful AKer is not too far away. In a similar vein, if you hadn't noticed, some areas have local meet ups, where AKers share music, equipment, ideas, and just good company. For example, this Events & Happenings forum has info on some that are currently ongoing. Lots of helpful folks attend these.
There are high voltages generated in tube equipment so read the safety guidelines to follow and stay alert. If you are unsure ask plenty of questions; don't guess or assume. Be safe and have fun with it.
Invaluable advice. Thank you Tinkerbelle
I just finished reading the article maxhifi shared and I can’t believe what a great help that was in clarifying capacitors. Amazing. And I will be updating my profile indeed. AK’ers seem like a pleasant and extremely knowledgeable bunch!
Seems like they purposely made them unserviceable hahahahaha
